static nat on asa
Answered Question
Feb 21st, 2007
Hi i need to change static association for a public ip to internal ip
right now i have following statment.
static (dmz,outside) 66.xx.xx.xx 192.168.50.91 netmask 255.255.255.255
it needs to be changed to
192.168.51.14 netmask 255.255.255.255
what should I need to do ?
do i need to add no statment to previous statement and execute new ?
Correct Answer by Jon Marshall about 9 years 7 months ago
yes you should do
no static (dmz,outside) 66.xx.xx.xx 192.168.50.91 netmask 255.255.255.255
then
You will then need to clear the xlate. Do not just enter "clear xlate" as it will remove all the xlates which will break all existing connections through the ASA.
Do
clear xlate global 66.xx.xx.xx
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 02/21/2007 - 09:47
yes you should do
then
Do
Jon
khary Wed, 02/21/2007 - 09:48
Yes you should put a "no" to remove the old statement then add the new statement. Ex:
static (dmz,outside) 66.xx.xx.xx 192.168.51.14 netmask 255.255.255.255
abinjola Wed, 02/21/2007 - 13:25
Hello
You need to first remove the previous entry
Also you need to add a new static
Then you need to clear the stale arp and xlate entries
cl xlate
cl loc
cl arp
See if it helps !
