Back up of ACS SE failed
Feb 21st, 2007
Hi, when i tried to do a backup with my ACS SE, the backup always fail. Even when doing it manually, it won't work. Any advice on the settings for it?
I'm using a Cerberus FTP server. Connectivity is ok..but i do not know why the connection always drop on the SE side.
Do i need to add my computer's hostname to the ACS SE?
Overall Rating: 5 (1 ratings)
GohJH Fri, 02/23/2007 - 00:40
Finally found out what was wrong. Thanks for your help.
Anonymous (not verified) Mon, 03/05/2007 - 11:20
What was your problem? I am having the same type of problem with my 1113 running 4.0 code. I am trying to use RDBMS via FTP and getting the same error. With Cerberus I get the following error:
"Error closing connection: An existing connection was forcibly closed by the remote host."
On the ACS SE side I get the following error in my RDBMS log:
"Failed to connect to FTP Server"
Jason
Vivek Santuka Tue, 03/06/2007 - 05:23
With RDBMS please ensure that the ftp account which you are using has read/write/delete permission.
Vivek
