02-21-2007 08:46 AM - edited 03-13-2019 03:56 PM
hi, i have a problem with ATA 186
when I light on the ATA it work very well after a certain moment the calls doesn't pass anymore Im forced to reboot every time when this problem happend
thanks
02-24-2007 04:08 PM
SW hangs, is a bad thing. Can you upgrade to latest code and try again ?
02-26-2007 07:21 AM
i had the last version , but the same problem once more
S/W Version 3.02.01(050616A)
firmware ATA030201SIP050616A.zup
02-26-2007 07:47 AM
IS this CCM? If so please report to IP telephony forum where there are many fellows that can help.
If it is CCME I would start looking at the status of the ephone, and try to ping the ATA when it freezes.
