port security on switch
Feb 21st, 2007
I have a question on the switch port security. A port on the security mode can allow upto 132 mac addresses that can be configured on that port. What exactly is that?
Is it the number of servers/pcs that can access that port from a particular vlan?
Thx
Shyam
Rolf Fischer Wed, 02/21/2007 - 08:57
Using the
switchport port-security maximum (1 - 132)
command you define the number of pcs that can access this port AT THE SAME TIME.
switchport port-security maximum 1
e.g. means that you have a port-security violation if a second mac-address is seen on the interface.
Depending your configuration the interface might shutdown if a violation occurs.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a0080648dd5.html#wp1184844
