Vista and WPA1 + WPA2 ssid
Feb 21st, 2007
We've tested MS Vista native supplicant on a SSID configure for WPA1 + WPA2 on ours WiSM. It wont work.
We've repeated the same test using a SSID configure for WPA1 and it works
First question : Why ?
Second question : What the difference between <wpa1 + wpa2> mode and WPA2 with wpa compatibility option enable. Did anyone do tests with that configuration.
k.rouwette Tue, 08/14/2007 - 03:10
I have the same problem. But i can only select WPA or WPA2 in the WPA1+WPA2 section. Only WPA or WPA2 is not available in the layer 2 security. You have any solution at the moment or which version of the WISM you have?
Thanks.
Trending Topics - Security & Network
