Java version 1.4.1_02
Answered Question
Feb 21st, 2007
Can someone point me to a link where I can download java 1.4.1_02?
Correct Answer by Joe Clarke about 9 years 7 months ago
If you're looking at this for the plug-in version, you should consider applying the patches on Cisco.com to increase the supported plug-in version to 1.4.2_12. Of course, the supported plug-in version can always be found on the CiscoWorks server under NMSROOT/htdocs/plugin.
Overall Rating: 5 (2 ratings)
Correct Answer
Joe Clarke Wed, 02/21/2007 - 12:28
getwithrob Wed, 02/21/2007 - 12:39
Can you be more specific as to where on Cisco.com to download from and what to download and install?
getwithrob Thu, 02/22/2007 - 05:45
We will be installing the DST patches for each of the 3 RME 3.5 servers and each of the 6 Campus Mgr servers which are all running on Solaris 2.8 this next weekend. The RME servers are @ IDU 13 and the Campus servers are all @ IDU 11.
After installing these DST patches, will the supported Java version then increase to 1.4.2_12?
Farmerc01 Thu, 02/22/2007 - 07:45
I cant get past the"java.lang.NullPointerException" error when trying to access a 6509 switch.
Its really driving me insane...
