Multiple Wan Addresses and routing
Feb 21st, 2007
Hi all,
I have a cisco 1721 router. It doesn't have the advanced ios security.
I would like to be able to give it multiple wan addresses given by isp and then route these so that I can give a user a static ip address. I would need to be able to forward all ports to this users own firewall and also have all traffic from him showing up as his static address.
Can I do this without the advanced ios security package ?
My config is below
Current configuration : 3362 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname cisco1721
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
enable secret 5 xxxxxxxxxxxxxxxxxxxxx
aaa new-model
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa session-id common
resource policy
clock timezone PCTime 12
clock summer-time PCTime date Mar 16 2003 3:00 Oct 5 2003 2:00
ip subnet-zero
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.60.1 192.168.60.99
ip dhcp excluded-address 192.168.60.151 192.168.60.254
ip dhcp pool sdm-pool1
import all
network 192.168.60.0 255.255.255.0
dns-server 203.97.33.1 203.97.37.1
default-router 192.168.60.254
ip tcp synwait-time 10
ip cef
ip domain name scorch.co.nz
ip name-server 203.97.33.1
ip name-server 203.97.37.1
no ip bootp server
username xxxx privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxx/
interface Null0
no ip unreachables
interface Ethernet0
description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
ip address 192.168.10.222 255.255.255.0
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
half-duplex
interface FastEthernet0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-10/100 Ethernet$$ES_LAN$$FW_INSIDE$
ip address 192.168.60.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.14.0.253
ip http server
ip http authentication local
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list 1 interface Ethernet0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=FastEthernet0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.60.0 0.0.0.255
access-list 100 remark VTY Access-class list
access-list 100 remark SDM_ACL Category=1
access-list 100 permit ip 192.168.60.0 0.0.0.255 any
access-list 100 deny ip any any
access-list 101 permit gre any any
access-list 101 deny ip 192.168.50.0 0.0.0.255 any
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 permit esp any any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login authentication local_authen
transport output telnet
line aux 0
line vty 0 4
access-class 100 in
transport input telnet
line vty 5 15
access-class 100 in
scheduler allocate 4000 1000
scheduler interval 500
end
