QRT menus
Feb 21st, 2007
Has anyone customised QRT? We want to add/delete categories and change the reason codes that are displayed on the screen.
Any help is much appreciated!
Erik
Overall Rating: 5 (1 ratings)
TOD BRUGGEMAN Wed, 02/21/2007 - 15:29
I'm also trying to customise the QRT menu.
I've found a QRTDictionary.xml file on the CCM server(4.2) at:
c\Program files\Cisco\Application\QRT\English_United_States\
I've modified this file on the CCM server that my phones are registered with and reset the phone, but I don't see the phone accepting the modified menu.
..tod...
ecstillman Thu, 02/22/2007 - 08:14
Tod, thanks for the reply.
Have you tried restarting Tomcat, Cisco Extended Functions, IIS Admin and WWW services?
Erik
ecstillman Thu, 02/22/2007 - 12:39
Simply restarting Cisco Extended Functions will do the trick; however, when I remove a Reason Code and/or Category, the result is displayed as (null) on my screen. Our workaround was to leave a space character, which effectively made it blank.
Erik
TOD BRUGGEMAN Thu, 02/22/2007 - 13:32
thks.... any luck adding net new reason codes?? I'm able to modify existing ones. I just can't get the phone to see the new ones that I've added to that QRTdictionary.xml file.
ecstillman Fri, 02/23/2007 - 08:20
hey tod ...did you notice a number after each comment? for instance, TextInterviewOnHookCat2Text5 < --- the new reason code should have a unique number.
To which Category are you adding the code?
-erik
TOD BRUGGEMAN Mon, 02/26/2007 - 08:26
I'm trying to add 2 additional options:
TextInterviewConnectedCat1Text10
TextInterviewConnectedCat1Text11
I make the changes and restart the EF service, but still do not see these additions. I can modify the text on TextInterviewConnectedCat1Text9 and see the changes displayed on the phone....just can't add net new options. ..thks...
ecstillman Mon, 02/26/2007 - 10:57
There must be another form that calls this xml page. Perhpas you should try posting this under IP Services? I think a developer would have the answer.
Please post back here if you have any luck.
Thanks!
