WebServer behind a PIX firewall
Feb 21st, 2007
I have a webserver that is on the network behind the firewall running a specific application. I was told that I needed to allow public access to that web application. How can I set the firewall to allow traffic to that specific webserver. Also, I need the traffic to be directed to: http://192.168.xx.xx/Public
What's the best way to set this up?
vitripat Wed, 02/21/2007 - 15:58
First .. do we have a public IP address for the domain of your webserver? If yes, lets assume that the public IP address is "y.y.y.y", then, you'll need following commands-
static (inside,outside) y.y.y.y 192.168.xx.xx
access-list 101 permit tcp any host y.y.y.y eq 80
access-group 101 in interface outside
clear xlate local 192.168.xx.xx
Outside users will be able to access your webserver using "http://y.y.y.y/Public"
Second .. if we dont have a separate public IP for the webserver, and need to use the public IP address given to outside interface of PIX, commands would be-
static (inside,outside) tcp interface 80 192.168.xx.xx 80
access-list 101 permit tcp any interface eq 80
access-gr 101 in interface outside
Now outside users will be able to access your server using the public IP on the outside interface of PIX.
Hope this helps.
Vibhor.
tgarner-library Wed, 02/21/2007 - 16:18
I received 2 errors:
f01(config)# access-list 101 permit tcp any interface eq 80
ERROR: % Invalid input detected at '^' marker. (the marker pointed to the e)
f-01(config)# access-gr 101 in interface outside
ERROR: access-list <101> is standard. Only "extended" or "ethertype" acls
can be attached to an interface
vitripat Wed, 02/21/2007 - 16:29
a Firewall module installed in a cat 6k switch or a 7k router ..
can you confirm what firewall do we have here ?
a IOS based firewall .. a PIX firewall or a firewall module ?
tgarner-library Wed, 02/21/2007 - 16:28
this is what I'm working with:
f01# show ver
Cisco Adaptive Security Appliance Software Version 7.0(4)2
Device Manager Version 5.0(4)1
Compiled on Tue 15-Nov-05 11:41 by root
System image file is "disk0:/asa704-2-k8.bin"
Config file at boot was "startup-config"
f-01 up 1 year 64 days
Hardware: ASA5510, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 64MB
BIOS Flash AT49LW080: @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : ☻CNlite-MC-Boot-Cisco-1.2
SSL/IKE microcode: ♥CNlite-MC-IPSEC-Admin-3.03
IPSec microcode : ☺CNlite-MC-IPSECm-MAIN-2.04
vitripat Wed, 02/21/2007 - 16:30
It seems that your ASA is working in "Transparent" mode .. for that commands would be a little different.
vitripat Wed, 02/21/2007 - 16:39
As this is a Transparent firewall, you only need following commands-
access-list ACL_IN extended permit tcp any host 192.168.xx.xx eq 80
access-group ACL_IN in interface outside
tgarner-library Thu, 02/22/2007 - 17:42
Well, I found out the hard way that you can only have 1 access-list per interface. When I created the access-list ACL_IN and the access-group ACL_IN - it broke many things. This is what ended up fixing this:
Step 1. static (inside, outside) netmask 255.255.255.255
Step 2. access-list outside_access_in extend tcp any host eq www
Step 3. no access-group outside_access_in in interface outside
Step 4. access-group outside_access_in in interface outside
and that worked!
