Router performance with NAT & CBAC
Feb 21st, 2007
I have a router that is 2610 with 12.3 ios ver, its already performing NAT with its two serial interface as outside NAT. Now its is experiencing degration like delay in sound and video conversation compared when is not in NAT. is it recommendable to use my router to perform Context-Based Access Control or any firewall function? thanks in advance!what is recommendation? I would also want to show you if theres something missing in my configuration (below).
version 12.3
service password-encryption
hostname xxxx
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxxxxxxxx
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
ip name-server 203.172.11.21
ip name-server 203.172.11.25
no ftp-server write-enable
interface FastEthernet0/0
ip address 10.1.1.1 255.0.0.0
ip directed-broadcast
ip nat inside
duplex auto
speed auto
no cdp enable
interface Serial0/0
description belltree-link-to-infocom
bandwidth 2048
ip address 203.xxx.xxx.xxx 255.255.255.252
ip nat outside
no cdp enable
interface Serial0/1
description xxxxxxxx-link-to-infocom
bandwidth 2048
ip nat outside
no cdp enable
ip nat pool isp-1 203.172.xxx.xx 203.172.20.xx prefix-length 28
ip nat pool isp-2 203.172.xxx.xx 203.172.20.xx prefix-length 28
ip nat inside source route-map isp-1 pool isp-1
ip nat inside source route-map isp-2 pool isp-2
ip classless
ip route 0.0.0.0 0.0.0.0 203.172.xxx.xxx
no ip http server
access-list 1 permit 10.0.0.0 0.255.255.255
no cdp run
route-map isp-1 permit 10
match ip address 1
match interface Serial0/0
route-map isp-2 permit 10
match ip address 1
match interface Serial0/1
line con 0
line aux 0
line vty 0 4
password 7 xxxxxxxxxxxxxxxxxxxx
login
end
xxxxxxx#
didyap Tue, 02/27/2007 - 10:47
There is no problem in your configuration. I would suggest going for a dedicated security device such as the pix firewall as the router is heavily loaded with two outside nat. Configuring CBAC will only slow down your device more.
