WIC version ?
Feb 21st, 2007
how do I determine which version of WIC I have? Not type, but verion. I'm told that version 1 WIC will not work in a 2800 series router.
Overall Rating: 4 (1 ratings)
sundar.palaniappan Wed, 02/21/2007 - 17:43
Use the command 'show diag' and look under the WIC slot and it would show you the type of WIC you have. You might see something like WIC-1DSU-T1-V2 or WIC-1DSU-T1 and the first one is version 2 as indicated by V2 in the part #.
Sundar
Danilo Dy Wed, 02/21/2007 - 18:07
Oh yes, Sundar is right. If the WIC is already installed even if it is not compatible you can use the sh diag :)
