iBGP configured on loopback address not reachable
Answered Question
Feb 21st, 2007
I have 2 routers connected, can ping each other on the F0/0 interfaces. Each has loopback interfaces which are the only once advertised in BGP (AS1).
Problem: I am not able to ping the loopback addresses.
Any ideas. This should be possible.
Config:
router bgp 1
synchronization
bgp log-neighbor-changes
network 1.0.0.0
neighbor 2.2.2.2 remote-as 1
neighbor 2.2.2.2 update-source Loopback0
no auto-summary
R2#sh run | beg bgp
router bgp 1
synchronization
network 2.0.0.0
neighbor 1.1.1.1 remote-as 1
neighbor 1.1.1.1 update-source Loopback0
no auto-summary
The routers can ping each other:
R2#ping 192.1.12.1
Sending 5, 100-byte ICMP Echos to 192.1.12.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 96/140/220 ms
What did I miss?
Debug message from R1:
*Mar 1 06:59:01.918: BGP: 2.2.2.2 active open failed - no route to peer, open a ctive delayed 29293ms (35000ms max, 28% jitter)
Correct Answer by sundar.palaniappan about 9 years 7 months ago
Jacob,
What Mike was asking you to do is to establish BGP peering one of two-ways.
1. If you want to use loopback addresses to peer then you need to have a static or another IGP route (not BGP) to the far end loopback address. You would also need to reinstate the 'update-source' command that you removed. You need a config similar to this one;
R1:
ip route 1.1.1.1 255.255.255.255 192.1.12.1
R2:
ip route 2.2.2.2 255.255.255.255 (next_hop_ip)
2. Your second option is to reconfigure, on both routers, the "neighbor (physical_int_IP_address) remote-as 7000' to the physical interface IP on the far end device. This doesn't need any static/IGP routing as the peering IP addresses are directly connected.
Sundar
Overall Rating: 4.5 (6 ratings)
deilert Wed, 02/21/2007 - 17:01
you can either add a static route to your loopbacks or change the update-cource loopback 0 to 'next hop self"
i.e.
neighbor 1.1.1.1 next hop self
mikedavi1 Wed, 02/21/2007 - 17:07
The adjacency between R1 & R2 does not come up because:
1) update-source Loopback0 tells BGP to establish a connection to/from it's Loopback0
2) BGP doesn't know how to reach the remote Loopback0
no route to peer, <=== this is the key message
There are two ways to correct this:
1) Best Practice - You'll need to configure either a static route or an IGP (RIP, OSPF, EIGRP, etc) to exchange the routes from Loopback to Loopback so that BGP can establish that connection.
2) Remove the update-source loopback0 clause from both routers' config. The connection will then be established from the directly connected interfaces. While this approach will fix your back-to-back router issue, it is generally not a recommended approach for real networks because of the potential for broken next-hop information and reliance on the directly connected interface for peering.
HTH,
Mike
mikedavi1 Wed, 02/21/2007 - 17:08
Looks like I didn't type quickly enough - I'm late to the party... :-)
ochiengjo Wed, 02/21/2007 - 17:30
Thanks Guys
What I would like to achieve is the second option given by "mikedavi1"
I have removed "update-source loopback 0"
But I still cannot ping both ends via the loopback interfaces.
R2#sh run | begin bgp
router bgp 1
synchronization
network 2.0.0.0
neighbor 1.1.1.1 next-hop-self
no auto-summary
R2#sh ip route | begin Gateway
Gateway of last resort is not set
C 192.1.12.0/24 is directly connected, FastEthernet0/1
C 2.0.0.0/8 is directly connected, Loopback0
C 192.1.25.0/24 is directly connected, Serial1/0.25
R1#sh run | begin bgp
router bgp 1
synchronization
network 1.0.0.0
neighbor 2.2.2.2 next-hop-self
no auto-summary
R1#sh ip route | begin Gateway
C 1.0.0.0/8 is directly connected, Loopback0
R1#ping 2.2.2.2
Sending 5, 100-byte ICMP Echos to 2.2.2.2, timeout is 2 seconds:
Any more ideas?
Correct Answer
sundar.palaniappan Wed, 02/21/2007 - 17:58
Jacob,
R1:
R2:
Sundar
ochiengjo Wed, 02/21/2007 - 20:17
Thanks everyone, I am well sorted out with this one now.
yashdedhiya Wed, 02/21/2007 - 23:53
1.First of all for IBGP to work ur synchronisation must be disabled.
no synchronisation.
2. To work IBGP with loopback ip u have to route the loopback ip pointing towards other router.
R1:
R2:
Rate this if it works.
Thanks.
Yash
