NM-HDV DSP Problems...
Feb 21st, 2007
Dear Friends
I have a Cisco 3640 with NM-HDV-2E1-60 module with VWIC-2MFT-E1.
The ios image is c3640-js-mz.123-19.bin and version is 12.3
I have a strange problem with the NM-HDV module.
I make the calls then these calls connect and after 2-3 seconds they drop, and the module doesn't free the channel, the channel stays busy...
All the lights on the nm-hdv dsp light up green.
I've tried to test the dsp's issuing the test dsp 0 command and then querying the dsp resource and status and it shows up the following
Dsp firmware version: 4.1.41
Maximum dsp count: 15
On board dsp count: 15
Jukebox available
Total dsp channels available 60
Total dsp channels allocated 60
Total dsp free channels 0
Querying dsp status......
It doesn't show the dsp status...
test dsp 1 (2, 3) commands say that Card 1 (2, 3) is not present.
How can I be 100% that the problem is because of the DSP's (if it is like that)
I'm saying this because I can buy new DSP's and change them, but I need to be 100% sure...
Any reply is appreciated!
dsweeny Tue, 02/27/2007 - 12:40
The issue could be with the DSPs, but the querying dsp status is not an issue. It is the normal behavior.
surenx_cisco Thu, 03/01/2007 - 13:49
Thanks for your reply.
I've done some tests and here's the result.
c3640_gw2# show dialplan number 12345678911
Macro Exp.: 12345678911
VoiceEncapPeer1
peer type = voice, information type = voice,
description = `',
tag = 1, destination-pattern = `111+',
answer-address = `', preference=0,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 1, Admin state is up, Operation state is up,
Outbound state is up,
incoming called-number = `', connections/maximum = 1/unlimited,
DTMF Relay = disabled,
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
type = pots, prefix = `11',
forward-digits default
session-target = `', voice-port = `0/0:0',
direct-inward-dial = disabled,
digit_strip = enabled,
register E.164 number with GK = TRUE
fax rate = system, payload size = 20 bytes
supported-language = ''
Time elapsed since last clearing of voice call statistics never
Connect Time = 1876, Charged Units = 0,
Successful Calls = 12, Failed Calls = 5, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "AC ",
Last Disconnect Text is "dsp error (172)",
Last Setup Time = 241131.
Matched: 12345678911 Digits: 3
Target:
So it seems that the problem is really in DSPs.....
surenx_cisco Sat, 03/03/2007 - 22:29
Well the NM-HDV module is connected to a PSTN so my guess, the DSP usage is used for transcoding.
