performance of css for web servers
Feb 21st, 2007
I have a customer complaining of slow response time BECAUSE of the content switch, which is load balancing web servers. Any idea of how to speed that up? Below is the config, Id be glad for any help.
!*************************** GLOBAL ***************************
ip route 0.0.0.0 0.0.0.0 XXXXXXXXXXXX 1
!************************** CIRCUIT **************************
circuit VLAN1
ip address XXXXXXXXXXXXX XXXXXXXXXXXXX
!************************** SERVICE **************************
service server1443
ip address XXXXXX
protocol tcp
port 443
keepalive port 443
keepalive frequency 2
keepalive type ssl
active
service server180
protocol tcp
keepalive port 80
port 80
keepalive type http
active
service server18080
ip address XXXXXXXXXXXXXXXX
protocol tcp
keepalive port 8080
port 8080
keepalive type http
active
service server2442
protocol tcp
port 443
keepalive port 443
keepalive type ssl
active
service server280
protocol tcp
keepalive port 80
port 80
keepalive type http
active
service server28080
protocol tcp
keepalive port 8080
port 8080
keepalive type http
active
!*************************** OWNER ***************************
owner Owner2
content i80
add service server180
add service sewrver280
protocol tcp
port 80
vip address XXXXXXXXXXXXX
advanced-balance sticky-srcip
active
owner Owner3
content i80
balance aca
port 443
protocol tcp
vip address XXXXXXXXXXXXXXXXXX
flow-timeout-multiplier 5400
active
owner Owner4
content i8080
protocol tcp
port 8080
vip address XXXXXXXXXXXXXXXXXXX
balance aca
active
CSS11503#
Overall Rating: 4 (2 ratings)
michael.e.reid Thu, 02/22/2007 - 01:22
I'd be very surprised if the content switch was slowing down access the webservers based on the config you have shown, I would look for other potential network issues - duplex settings maybe on the CSS ?
There is an issue with the CSS when uploading through the CSS it has a 10-12K window size (although this has been increased to about 40K in Version 8 of the WebNS software)
jjoseph01 Thu, 02/22/2007 - 05:15
thanks for the response. How would I go about checking the window size out, and if needed, how would I go about increasing that to version 8? Im not real familiar with it. Any help would be appreciated.
michael.e.reid Thu, 02/22/2007 - 05:56
Well, this problem causes slow upload behaviour through the CSS, so firstly, is this the problem your customers face ? If not then you have another issues.
If you have access to CCO you can download the images from cisco.com software centre. The upgrade procedure is in the release notes.
In my company I can download images from Cisco but not sure how you get your images for routers/switches/ other devices.
cheers,
Mike
jjoseph01 Thu, 02/22/2007 - 06:48
Customer complains of slow ftp speed to their webservers. This does sound like what you mention to me. Ill take a look at that first, thanks. Would this be the same as an image upgrade?
Gilles Dufour Thu, 02/22/2007 - 06:25
I would first capture sniffer traces of a client accessing the webserver directly and then the same client accessing the same page through the CSS.
Compare the 2 traces and how long it takes to get the response.
Sometimes people *feel* that it is slower.
But data proves it's not.
Gilles.
jjoseph01 Thu, 02/22/2007 - 06:51
show ver below:
CSS11503# show ver
Version: sg0810106 (08.10.1.06)
Flash (Locked): 08.10.1.06
Flash (Operational): 08.10.1.06
Type: PRIMARY
Licensed Cmd Set(s): Standard Feature Set
jjoseph01 Thu, 02/22/2007 - 07:31
Is there a way to set the interface to full duplex on the content switch?
Gilles Dufour Thu, 02/22/2007 - 08:22
by default the CSS is in auto mode, so it should negotiate with the switch full duplex.
Do a 'sho phy' to verify your current settings.
If you're not in full-duplex, you can force it with the command
interface 3/1
phy 100Mbits-FD
Gilles.
jjoseph01 Thu, 02/22/2007 - 08:47
Yeah, just did the "phy" command. Very different that what I have seen on a router or switch. Thanks, that did fix the issue.
