traffic monitoring
Feb 21st, 2007
i have a 6509 (version 12.2), and have some customers with static ip addresses. I need to mirroring the traffic from these customers and send to a hardware filter. Is using SPAN function the only way to do that?
I tried to do that on a BigIron layer3 switch. It's much eaiser to do that with the following configuration:
interface ether 5/15
ip policy route-map MAP1
route-map
match ip address 1
set mirror-port 5/12
ip access-list standard 1
permit ip host xx.xx.xx.xx
mirror-port ethe 5/12
Is there any way on Cisco platform similar to the BigIron solution? I have to do that on the cisco device because I have some customers connected to cisco, not through bigiron.
thanks for your comment
hoogen_82 Thu, 02/22/2007 - 00:02
Wow thats cool. But i guess for our cisco span is the only solution. The more important thing, it cannot be based on IP as is this case you are doing with BigIron.
Cheers
Hoogen
Do rate if this helps :)
