02-21-2007 06:10 PM
any open source application that does almost the same as the RME? particularly the configuration management where running config and startup config are being compared..
thanks
Solved! Go to Solution.
02-21-2007 06:46 PM
There is a tool on sourceforge that is able to compare configs. I think it relies on Perl scripting.
It requires a fair bit of configuration and I disregarded it due to it being a single purpose app, whereas RME does so much more than config backups / comparisons.
(ncat.sourceforge.net)
02-21-2007 08:28 PM
You may want to look into Pancho (http://www.pancho.org/) and Rancid (http://www.shrubbery.net/rancid/). Pancho is in a bit of flux right now, but Rancid is still actively maintained.
02-21-2007 06:46 PM
02-21-2007 08:28 PM
02-22-2007 01:06 AM
thanks a lot.
i am already using RME for cicso routers, but there are 100 plus switches (allied telesyn) that are not cisco. i just hope they are supported..
