Debug command
Answered Question
Feb 21st, 2007
Any manual of how to use debug command specific to a packet or IP address. Since it take lot of memory if I run that randomly.
Correct Answer by vitripat about 9 years 7 months ago
We dont need to apply this access-list on any interface. It is completely independent of existing access-lists on device. The sole pupose of these ACLs is to match the traffic we need to capture by using them in the capture command.
Overall Rating: 4 (3 ratings)
vitripat Thu, 02/22/2007 - 03:45
Debug command was the old way of capturing the packets. This command has been deprecated in 7.x versions. There is a better way available to capture the packets. For that we can use the "capture" command. Here is an example-
suppose there is a host a.a.a.a on the inside interface of PIX/ASA and I need to capture all the outbound packets from this host. For this, I can apply captures using folloaing commands-
-> access-list capi permit ip host a.a.a.a any
-> capture cpi access-list capi buffer 1000000 packet-length 1518 interface inside
Using access-list gives me more strength and granularity to capture only the packets I need. Later I use that access-list in the capture command. To download the capture files, I need to point my browser to-
https://interface_ip/capture/cpi/pcap
(assuming PDM/ASDM is installed)
You can also use "copy" command to transfer the capture file to a tftp server.
Link for capture command-
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_70/cref_txt/c.htm#wp1950270
Link for copy command-
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_70/cref_txt/c.htm#wp1970556
Hope this is helpful.
Vibhor.
sivakumar.ks Thu, 02/22/2007 - 19:23
Hi ,
Thanks for your response. Do we need to apply accesslist exclusively to an interface. Do the above access-list capi is independent of exisiting access-list.
siva
Correct Answer
vitripat Thu, 02/22/2007 - 20:02
