BGP negibhors. Same remote AS
using private AS numbers. RouterA is set for AS 1. I already have a neighbor to RouterB configured for remote AS 2 through a wan connection. I want to peer with RouterC through an ethernet connection but they are also using AS 2. Is this possible? The AS numbers used in this post are just an example
Thank you,
sundar.palaniappan Wed, 02/21/2007 - 21:07
Yes, it is possible. As long as the IP reachability is there between the peering devices it should work fine. BGP peering doesn't care about the underlying media type used and in other words, it's media independent. You can have a single router with multiple peers in another AS.
Sundar
royalblues Thu, 02/22/2007 - 03:21
Ahmed,
The conenction between router A and router C would still be an EBGP connection as they are in different AS.
IF you plan to run BGP between router B & C then it would be an IBGP conenction.
Narayan
Danilo Dy Thu, 02/22/2007 - 04:46
RouterA = AS1
RouterB = AS2
RouterC = AS2
RouterB and RouterC should be in iBGP
It's definitely possible to connect RouterA to both RouterB and RouterC using eBGP. With this, RouterA will have distributed/redundant connection to AS2
If there is no interconnection between RouterB and RouterC, let us know.
Danilo Dy Fri, 02/23/2007 - 19:17
You already wrote a thank you note, thus that mean everything is okay now?
