Router 1841
Answered Question
Feb 21st, 2007
we have one query with 1841 router.one customer is asking for router over which two different line,one for data and other for voice,terminats.so i want to know the technology behind this.
Correct Answer by sachinraja about 9 years 7 months ago
Hello Lalit,
1841 will not support voice... so, if you want both data and voice, you might have to look atleast at a 2800 router... there are a lot of voice cards that the 2800 supports.. your statement can mean that the customer wants a pure data line , through which the traffic flows, and can also need a voice port, which can be used for setting up some VOIP infrastructure... You can probably question back the customer and get his exact voice requirement, since for each requirement there can be a solution or a router module....
Hope this helps.. all the best...
Raj
Overall Rating: 3 (1 ratings)
Correct Answer
sachinraja Thu, 02/22/2007 - 19:00
Hello Lalit,
Raj
