Facing problem with two way NATing
Feb 21st, 2007
Following is config & debug info.
My target is sftp to server 192.168.10.25 from 155.107.90.48 network. Please help. Its urgent.
interface FastEthernet0/0
ip address 10.156.67.3 255.255.255.224
Connected to CDSL network
ip accounting output-packets
ip nat inside
speed 100
full-duplex
interface FastEthernet0/1
ip address 155.107.90.59 255.255.255.240
Connected to DMZ
ip nat outside
speed 100
full-duplex
ip nat inside source static 192.168.10.25 155.107.90.56
ip nat outside source static 155.107.90.62 10.156.67.4
ip classless
ip route 10.156.0.0 255.255.0.0 10.156.67.1
ip route 155.107.90.0 255.255.255.0 155.107.90.62
ip route 192.168.10.0 255.255.255.0 10.156.67.1
show ip nat translations
Pro Inside global Inside local Outside local Outside global
--- 155.107.90.56 192.168.10.25 10.156.67.4 155.107.90.62
--- 155.107.90.56 192.168.10.25 --- ---
--- --- --- 10.156.67.4 155.107.90.62
Debug out put of IP translations:
00:02:21: NAT*: s=155.107.90.62->10.156.67.4, d=155.107.90.56 [25711]
00:02:21: NAT*: s=10.156.67.4, d=155.107.90.56->192.168.10.25 [25711]
00:02:26: NAT*: s=155.107.90.62->10.156.67.4, d=155.107.90.56 [25757]
00:02:26: NAT*: s=10.156.67.4, d=155.107.90.56->192.168.10.25 [25757]
00:02:31: NAT*: s=155.107.90.62->10.156.67.4, d=155.107.90.56 [25764]
00:02:31: NAT*: s=10.156.67.4, d=155.107.90.56->192.168.10.25 [25764]
00:02:36: NAT*: s=155.107.90.62->10.156.67.4, d=155.107.90.56 [25771]
00:02:36: NAT*: s=10.156.67.4, d=155.107.90.56->192.168.10.25 [25771]
00:02:39: NAT: s=155.107.90.62->10.156.67.4, d=155.107.90.56 [20246]
00:02:39: NAT: s=10.156.67.4, d=155.107.90.56->192.168.10.25 [20246]
00:02:41: NAT*: s=155.107.90.62->10.156.67.4, d=155.107.90.56 [25779]
00:02:41: NAT*: s=10.156.67.4, d=155.107.90.56->192.168.10.25 [25779]
00:02:42: NAT: s=155.107.90.62->10.156.67.4, d=155.107.90.56 [20247]
00:02:42: NAT: s=10.156.67.4, d=155.107.90.56->192.168.10.25 [20247]
00:02:46: NAT*: s=155.107.90.62->10.156.67.4, d=155.107.90.56 [25787]
00:02:46: NAT*: s=10.156.67.4, d=155.107.90.56->192.168.10.25 [25787]
00:02:48: NAT: s=155.107.90.62->10.156.67.4, d=155.107.90.56 [20264]
00:02:48: NAT: s=10.156.67.4, d=155.107.90.56->192.168.10.25 [20264]
hoogen_82 Wed, 02/21/2007 - 23:54
What are you trying to do nating source based or destination based flow? Explain your traffic flow please.
Cheers
Hoogen
siddhesh.bane Thu, 02/22/2007 - 00:01
My network(DMZ) is 155.107.90.48/240 & flow is
155.107.90.48<-->10.156.67.0<-->10.156.65.17----WAN Connectivity-----10.156.65.18<-------------->192.168.10.25(Other END)
We are using two way nating because our LAN use both 10.--- network & 192.168.--- network
