No Route even as there is a static route
Feb 22nd, 2007
Hi there,
there is a PIX 525 with 7.2(2) running.
The following issue occured:
- suddenly the PIX cannot find a route to one specific host
- There is a static route to the net in which the host resides.
- The hosts one figure above and below are reachable (cannot reache x.x.x.243 but x.x.x.244 and 242).
- The specific host is only from one single interface unreacheable, from the others it can be reached.
- The connection/routing works for a day and suddenly the routing fails.
- There is also ospf running on this machine (as a ASBR).
Is there a bug in the IOS?
Does static routing and ospf not work together?
What can I do to get closer to the cause or how can the issue be resolved?
Thanks in advance
Overall Rating: 4 (1 ratings)
lemmy1234 Thu, 02/22/2007 - 03:28
Historicaly there is static NAT configured. The source ip stays the same on the translated interface.
In the new IOS there is additionaly "enable traffic through the firewall without NAT" enabled.
In the firewall log is the following entry:
%PIX-6-110001: No route to x.x.x.243 from x.x.x.x
Before the issue occured the first time no changes have been made on routing (except ospf dynamic entries) or natting.
lemmy1234 Thu, 02/22/2007 - 04:46
thank you for your reply.
Unfortunatelly the routing table is too long
to post here and I am also not allowed to post it.
The host which is not reachable is in the same static route included like the hosts which can be reached (even in the case of failure).
The route is during the failure still in the routing table and other host have to use the entry (because I can get them via ping).
By the way currently is all working - no failure. So I suppose that there is currently no misconfiguration visible.
The problem occurs "suddenly" and vanishes as soon as I reload the machine.
Can you tell me on which things I shoud have a look on - especially if the failure occurs?
