Configure as a repeater
Answered Question
Feb 22nd, 2007
I have to configure a second AP as a repeater, and these are the steps that I done:
1- the 1st AP is working as autonomous AP
2- the seconde one i make it associated with the SSID of the 1st AP
3-I configured the roll of the 2nd AP as repeater
I think that this only are the steps to do it, as all the two AP are in standard configuration.
Is there any other step to do to configure the AP as repeater??
Correct Answer by prakashj about 9 years 6 months ago
Hi omar,
Pls go through the below mentioed link.
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/accsspts/ap350scg/ap35ch12.htm
It may help you
Regds
Saji k.s
Overall Rating: 5 (2 ratings)
omar.elmohri Thu, 02/22/2007 - 07:24
Hello Rob,
This step are the same of what I did. But at the end the Repeater cannot associate to the AP ??
I'll try all the steps for a second time (after the weedend I'll do it) and I'll send you a reply if that will work.
Thank you anyway.
omar.elmohri Sun, 03/04/2007 - 02:20
This is a part of the configuration file of the AP configured as a repeater :
(On the root, I have a default configuration with an SSID : DJEZZY Wifi Hotspot. unless I did all the steps, but I can't arrive to associate the Repeater to the root)
Note : the APs have all the default configuration.
CONFIG FILE:
Current configuration : 1218 bytes
version 12.3
no service pad
service password-encryption
dot11 ssid DJEZZY Wifi Hotspot
infrastructure-ssid optional
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role repeater
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface BVI1
no ip address
no ip route-cache
Omar,
omar.elmohri Sun, 03/18/2007 - 06:28
Do you have the same problem to configure a repeater??
You use what kind of security??
Can you post the part of the SSID ??
I have fixed my problem as I'm using Open Authentication.
