I need help Cisco 2600
(i can?t speak english...)
I have the Cisco 2600 with a ISDN and a Analog Modul
A PC what have a ISDN Card i can connect to the Router an work in my Network.
With a PC what have a 56K Modem or a 28k Modem i can connect but not work. Everytime.. 1 / 2 Minutes i get a disconnect (No Massage)
I Have try to set the IDL Time higher.. and i have set the connecttime high.
I configurate the Router four Days now.. and now.. i give it up..
Pleas help me..
----------- the Config ----------
(I have the IP?s what have the same number marked with a "X" "Y" "Z"
I hope everybody can help me !! I want go back to my famely !!
Overall Rating: 5 (1 ratings)
Richard Burts Thu, 02/22/2007 - 04:40
Kai
I have looked at the config that you posted and I believe that the problem is that there is not a dialer-group for the async interface to identify interesting traffic. With no interesting traffic the idle timer will run out and terminate the call. I suggest that you add dialer-group 1 under the async interface. Try it and let us know if it helps.
Rick
thanks for your help.
my english is realy terrible.. :-)
pleas show my new config.
Than i have a connection txt where you can see that i can connect.
but i belive that (so i have see it by connect with ISDN) the call from my Client PC get no route to my network here. (peer)
I call the router with a 9,6 Kb Modem (Mobilephone) but i think that is not the problem. It have to worke!
Now i am 12 h here and i will crazy!! :-)
Thanks for Help
Kai
Richard Burts Thu, 02/22/2007 - 08:48
Kai
Could you post the output of route print from the PC when it is dialed in?
Rick
Hey Rick,
i have no print when it is dialed in! But i have chang the text.. but i m not to 100 % sure!
I will drive to the other PC now and will be back in the next time!
Only for you :-) no..
my last hope your are
I hope the call with the ISDN PC will help us. But i m not sure that the ISDN Canal is free! But i try!!
Thanks so much
