7941G firmware upgarde mistake
Feb 22nd, 2007
OK I've been a fool!
I normally only look after data, so I bought a 7941G SIP 8.0(2) phone.
Just wanted to get a feel for its deployment so don't have aCall Manager.
I mistakenly put cmterm-7941_7961-sip.8-0-4SR3.zip o the TFTP server.
So now the TFTP logs show its not looking for the SIP files.
Is there a way of resetting it without CM
IC
mchandak Thu, 02/22/2007 - 06:12
Are you trying to upgrade the firmware on the phone or downgrade it ??
Also, can u paste the errors that you are seeing in tftp traces ?
Ian Cowley Thu, 02/22/2007 - 07:42
I was trying to upgrade the SIP for 8.0(2) to 8.6...but happy to down/upgrade to any thing now! I'm pretty sureI've now got the CM code on it...but without a CM. I just want SIP.
It should be pulling POS and P000 files for SIP.
TFTP
Feb 22 11:22:00 tftpd.rsm.local atftpd[22799.-1208575056]: Serving term41.default.loads to 172.20.1.126:49152
Feb 22 11:22:01 tftpd.rsm.local atftpd[22799.-1208575056]: Serving jar41sip.8-0-3-34.sbn to 172.20.1.126:49153
Feb 22 11:22:01 tftpd.rsm.local atftpd[22799.-1208575056]: Serving cnu41.3-1-3-32.sbn to 172.20.1.126:49154
mchandak Fri, 02/23/2007 - 13:47
On the TFTP Server, create a OS79XX.txt file with the name of the firmware you want the phone to use. Do not mention the file extension in the name
Ian Cowley Sat, 02/24/2007 - 06:48
cat OS79XX.TXT
P003-08-2-00
[root tftpboot]# ls -l P*
-rw-r--r-- 1 root root 128888 Jul 7 2005 P003-07-5-00.bin
-rw-r--r-- 1 root root 129292 Jul 7 2005 P003-07-5-00.sbn
-rw-r--r-- 1 root root 129240 Mar 2 2006 P003-08-2-00.bin
-rw-r--r-- 1 root root 129644 Mar 2 2006 P003-08-2-00.sbn
-rwxr-xr-x 1 root root 129824 Dec 12 16:54 P003-08-6-00.bin
-rwxr-xr-x 1 root root 130228 Dec 12 17:21 P003-08-6-00.sbn
-rw-r--r-- 1 root root 689278 Jul 7 2005 P0S3-07-5-00.bin
-rw-r--r-- 1 root root 461 Jul 7 2005 P0S3-07-5-00.loads
-rw-r--r-- 1 root root 689682 Jul 7 2005 P0S3-07-5-00.sb2
-rw-r--r-- 1 root root 461 Mar 2 2006 P0S3-08-2-00.loads
-rw-r--r-- 1 root root 785338 Mar 2 2006 P0S3-08-2-00.sb2
-rw-r--r-- 1 root root 689777 Feb 22 10:54 P0S3-08-2-00.zip
-rwxr-xr-x 1 root root 459 Dec 12 17:40 P0S3-08-6-00.loads
-rwxr-xr-x 1 root root 753560 Dec 12 17:20 P0S3-08-6-00.sb2
-rw-r--r-- 1 root root 681556 Feb 21 19:21 P0S3-08-6-00.zip
