Explain Please
Feb 22nd, 2007
Dear All!
What is the basis concept of enabling
IP CEF
command if I m using pbr in my 2821.
waiting ur favable reply.
spremkumar Thu, 02/22/2007 - 23:01
As per the supporting doc the optimal way to do Policy Based Routing with better performance you need to enable CEF in your box.
Its otherwise called as CEF-Switched PBR
Before CEF was introduced the PBR was done on the path derived using Fast-Switching which is otherwise called as Fast-Switched PBR..
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a008075fae6.html#wp1005373
regds
