AXL busyTrigger and maxNumCalls not applying
Feb 22nd, 2007
Hi All
I'm submitting an AXL SOAP query as follows to try to change the busy trigger and max calls parameters for a line.
It appears that when I submit this, regardless of the attributes I set in the AXL POST, the two parameters are set to the default of 2/4 respectively.
I suspect this is because of the way the query works; i.e. it removes all lines, then reassigns the specified lines to the phone.
Anyone seen this or have any ideas?
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<SOAP-ENV:Body>
<axl:updatePhone xmlns:axl="http://www.cisco.com/AXL/API/1.0" sequence="1">
<name>SEP001AA27AE6F5</name>
<lines>
<line index="1">
<label>NumCallTest</label>
<display>CLITest</display>
<dirn>
<pattern>8486</pattern>
<usage></usage>
<routePartitionName>PT_Phones</routePartitionName>
</dirn>
<ringSetting>Use System Default</ringSetting>
<maxNumcalls>6</maxNumcalls>
<busyTrigger>3</busyTrigger>
<callInfoDisplay>
<callerName>true</callerName>
<callerNumber>true</callerNumber>
<redirectedNumber>false</redirectedNumber>
<dialedNumber>true</dialedNumber>
</callInfoDisplay>
</line>
</lines>
</axl:updatePhone>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Thanks!
Aaron
Overall Rating: 4.5 (2 ratings)
stephan.steiner Mon, 02/26/2007 - 09:34
I'm afraid you're using incorrectly. If you read the documentation, it states that only the uuid is taken into account.. so you'd need to use something like
and that's it for the directory number.
As having a element results in the existing lines being removed and new ones added, and since the new one isn't properly configured, I suspect that's why you don't get it to change anything.
BTW, what do you get in terms of return value?
If the update worked out, you should get a new uuid.
Aaron Harrison Tue, 03/20/2007 - 05:18
Hi Stephan
Thanks for the suggestion - I've used the UUID, however still no luck. Get a 200 back, all other lines on the phone disappear, and the line I ask for is applied (just as before).
No change to the maxcalls/busy trigger though.
Content-type: text/xml
Content-length: 791
http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> http://www.cisco.com/AXL/API/1.0" sequence="1">SEP123412341234
Test-mar20
Test-mar20
Use System Default
6
true
true
false
true
HTTP/1.1 200 OK
Content-Type: text/xml
Content-Length: 521
http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
http://www.cisco.com/AXL/API/1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.cisco.com/AXL/API/1.0 http://cm1/CCMApi/AXL/V1/axlsoap.xsd" sequence="1">
{21DF477B-9210-41A1-A76B-FB51B3BFEAEF}
Any other suggestions?
Aaron
fred.s.mollenkopf Tue, 03/20/2007 - 09:48
Aaron,
Just a suggestion, on the try changing it to with an uppercase C. This is how it's written in the Schema documentation (the one is referenced was 4.1.3).
An I think you already stated but just to be thorough, this does overwrite the existing lines.
Fred
Aaron Harrison Fri, 03/23/2007 - 05:17
Hi Fred
Erm...yeah... that was it. I feel sheepish!
I am cursing my Windows background now.
Of course, it would have been nice to get an error back from the service intead of a 200/OK...
Aaron
fred.s.mollenkopf Mon, 03/26/2007 - 07:24
Dude I feel your pain. Plenty of times I've had the minor typo in an AXL script which has led to hours of frustration. Glad it works now.
Fred
