Sup2/MSFC2 PCMCIA Flash card - hot swappable?
Answered Question
Feb 22nd, 2007
Our 7603 has a PCMCIA 24MB Flash card in it from which the IOS is loaded (slot0:). Is it possible to remove this card while the router is up and running? Is there a procedure to effectively "dismount" the device prior to removing it, if so? Thank you,
Bob
Correct Answer by glen.grant about 9 years 7 months ago
You can just take it out no special procedures , you will see it in the logs but it doesn't affect anything .
Overall Rating: 5 (1 ratings)
Correct Answer
glen.grant Thu, 02/22/2007 - 07:04
