CVOICE Home Lab
Feb 22nd, 2007
I started studying CVOICE from "Authorized Self-Study Guide Cisco Voice over IP (CVoice), by Kevin Wallace" which is a great book. At the end of each chapter there are labs, I see that I need;
1 x Router with one serial and one FXS port
1 x Router with two serial interface
Does it mean that I need?;
3 x 2600 series routers
2 x VIC-FXS
4 x WIC-1T
Or do I need additional equipment?
Of course I would like to go further with QOS, IPTT, CIPT 5.0 and GWGK. If I will get those 2600's, 2 x VIC-FXS and 4 x WIC-1T, can I use them for the rest of the studying for CCVP or will they be useless?
I know this is a long journey, I do not want my equipment to be out-dated till I will achieve my CCVP.
Thanks for letting me know what your thoughts are,
ahmednaas Thu, 02/22/2007 - 12:32
For the roouters, get 2600XM's with RAM Maxed out at 256/48. This way you can run the latest 12.4/12.4T software with the latest voice features.
ellis_b Thu, 02/22/2007 - 13:16
you should consider getting some XM series routers like the person just suggested - or you can get some 3640s if you want - those too will run IOS you will want to practice on. if you really want some good equipment that will not become out-dated, take a look at the ISR routers - just make sure you get the correct interfaces and DSPs.
