BRI
Feb 22nd, 2007
People,
Troubleshooting isdn basic rates, any idea why a second bearer channel would not want to come up?
Checked the dial strings and config...cant see anything wrong..any suggestions?
Thanx in advanced.
erniedavis Thu, 02/22/2007 - 13:04
You may want to verify the following commands in your configuration to bring both bearer channels up (these are entered in the interface command):
ppp multilink
dialer load-threshold load [outbound | inbound | either]
Hope this helps.
cisco_trouble Thu, 02/22/2007 - 21:52
yes, this is the 1st thing i checked, configs are correct. And on the telco side, what possible problems? Layer 2 comes up, but get a bearer channel error. 1st channel comes up.
spremkumar Thu, 02/22/2007 - 22:14
If possible can you post out the config as well as the exact error logs available out there.
regds
