Syslog Question
I am capturing syslog events from numerous cisco switches and have noticed my 2950 switches generate link up/down as errors when a connected device is rebooted. I obviously need to collect all error level events from these switches but do not really consider these link up/down messages as being at the error level. Is there any way to change these events from being considered errors to being considered informational events?
ahmednaas Thu, 02/22/2007 - 08:12
You can change the logging level on the switch. You should have a statement like:
logging trap critical
There are seven levels:
0 emergencies
1 alerts
2 critical
3 errors
4 warnings
5 notifications
6 debugging
Richard Burts Thu, 02/22/2007 - 08:16
Ahmed
Tom's original post specified that he wants to continue to collect all error level messages except for the link up/down messages. Changing the logging level would prevent that.
Rick
Richard Burts Thu, 02/22/2007 - 13:05
Tom
I do not know if it is a version difference, feature set difference, or what, but it works fine on my 2950.
SW1#sh ver
IOS (tm) C2950 Software (C2950-I6K2L2Q4-M), Version 12.1(22)EA6, RELEASE SOFTWARE (fc1)
SW1(config)#int fa0/7
SW1(config-if)#no logging event link-status
SW1(config-if)#
SW1(config-if)#^Z
SW1#sh run int fa0/7
Building configuration...
Current configuration : 150 bytes
interface FastEthernet0/7
switchport mode access
switchport nonegotiate
no cdp enable
spanning-tree portfast
end
Rick
