Java Plugin Version Question #2 -
Answered Question
Feb 22nd, 2007
I'm thinking the my other question may get lost as the previous post is getting a little cluttered up:
Question:
We will be installing the DST patches for each of the 3 RME 3.5 servers and each of the 6 Campus Mgr servers which are all running on Solaris 2.8 this next weekend. The RME servers are @ IDU 13 and the Campus servers are all @ IDU 11.
After installing the DST patches, will the supported Java version then increase to 1.4.2_12.
Correct Answer by Joe Clarke about 9 years 7 months ago
We only ever have ONE true supported version of the plug-in. After applying the DST patches for any currently supported version of LMS, the One True Supported JPI will be 1.4.2_12. All others will not work.
Overall Rating: 5 (2 ratings)
Joe Clarke Thu, 02/22/2007 - 10:27
The supported version of the JPI will be 1.4.2_12. This is the same version of the supported JPI used by LMS 2.6 with its DST patch.
getwithrob Thu, 02/22/2007 - 10:35
Thanks for getting back....
Let me make sure I've got this straight...
Once the DST patches are installed, the supported Java Plugin will be 1.4.2_12?
Correct?
If so, will 1.4.1_02 still work or will the JPI have to be upgraded from 1.4.1_02 to 1.4.2_12?
It may appear I'm a little slow but I'm from Oklahoma! That's my story and I'm sticking to it...
Correct Answer
Joe Clarke Thu, 02/22/2007 - 10:36
