Site to Site VPN assistance request
Feb 22nd, 2007
I have a site to site VPN configured with a Cisco 1811 router at the remote end and a Pix 525 at HQ. The tunnel between the 2 sites is up. I cannot web browse from a PC at the remote end. I can trace route to a website but not browse the web. I am not sure if it is a NAT issue but I dont have a lot of experience with configuring PPPOE. It is also split tunneling, (which I don't want) the web traffic when I do a trace route. So not only does it not work, the trace shows the http/web traffic is trying to directly connect over the ISP instead of thru the tunnel. I have attached the configuration of the remote 1811. Thanks.
hwang Thu, 02/22/2007 - 20:06
I thought your issue was related to split-tunnel. I am glad you resolved it youself.
Henry
mark.blanchfield Fri, 02/23/2007 - 05:54
It seems by removing the NAT command from the dialer interface, it started routing the http traffic over the tunnel instead of directly out to the Internet. I have numerous other site to site VPNs where they are routing the http traffic directly to the web which we don't want. These are cable modem terminated connections so there is no dialer interface. I have attached the configuration of a remote 1811where this web traffic is not going over the tunnel like we want it to. Any ideas about why this is happening? Thanks.
