easy vpn urgent plz
Feb 22nd, 2007
hi i m setting up easy vpn between two 3640 routers, 1 is a server and the other is client, ios is c3640-jk9o3s-mz.124-12,, on the server i had a loopback address of 12.0.0.20, now at client under client configuration i selected mode client, everything goes well i m asked for xauth, i entered n on client a loopback is formed and ip from the pool is assigned to it ( my pool was 12.0.0.1 - 12.0.0.5) ip assigend was 12.0.0.1, at server i issued reverse-route under dynamic-map, so after assingning the ip it created a static route to 20.0.0.1/32 !!! till here its fine but wat abt the client ??? client didnt setup any route for the the receiving ip !! now suppose if i want to ping the loopback of server 20.0.0.20 the client wont be able to ping it cause the same network is found on its loopback interface right, now plz tell me the solution of it, like server is there any way to inject the route automatically or do i have to do anything else plz tell me
thanks in advance
purohit_810 Thu, 02/22/2007 - 12:40
shaila,
you are full of queries????
Working on your problem.
Dharmesh Purohit
shaila_rox Fri, 02/23/2007 - 01:23
thanks, actually i m working in a lab environment thts why whatever problem i face i look in cisco for solution, and if i dnt find it then i ask u guys, since u all r working in real scenarios ur advices are always precious for me
eabonalla Fri, 02/23/2007 - 01:42
crypto isakmp client configuration group Group1
key secret
dns 10.1.1.2 124.107.27.147
pool SDM_POOL_1
acl ACL_VPNClients
include-local-lan
netmask 255.255.255.240
ip access-list extended ACL_VPNClients
permit ip 10.1.0.0 0.0.0.255 any
permit ip 192.168.2.0 0.0.0.15 any
in this example clients are going fetch a configuration from the server. Access-list is provided for routing to be used by clients.
hope this helps.
