DNS-Guard and ASDM
jeffland_98
When I use the ASDM interface to my ASA 5520 I get a message that it did not recognize the dns-guard command while parsing the running cfg. Is this a bug with ASDM? How do I tell if dns-guard is working? Thanks.
Fernando_Meza
Level 7
Level 7
Hi .. basically ADSM can't interprete that command .. the command will still do the job on the runnning configuration.
what version of code and ASDM are you using ?
It's the version that came with the ASA:
ASDM 7.0(5)
