clear ip route necessary after redistribution change?
Feb 22nd, 2007
Let's say I have following redistribution configured:
router rip
version 2
redistribute eigrp 1
redistribute ospf 1
network 10.0.0.0
default-metric 5
no auto-summary
It works, no problem. Now I change the redistribute statements to contain route map:
redistribute eigrp 1 route-map rip-in
redistribute ospf 1 route-map rip-in
The problem is that the change does not take place until I execute "clear ip route *" on the router (ie. the routes, that are denied by the route map continue to be redistributed).
The question is: is this normal behaviour? Is this manual intervention always necessary?
Overall Rating: 4 (1 ratings)
sundar.palaniappan Thu, 02/22/2007 - 14:46
I don't know what's Cisco's recommendation is but I can tell you what my experience has been in this regard. In most situations, any changes that I had made, similar to the one that you did, didn't require clearing the ip routes. There has been one or two situations that I had to manually clear the route(s) for the change to take effect.
I strongly believe the router should recognize the change and effect it without any manual intervention but then there may be bugs in the IOS version that's used. Though, the routes should repopulate quickly on clearing them you have to be careful clearing the routes, especially, if it's a high visibility network.
Sundar
