Are the command lines subject of the CCIE exam ?
Feb 22nd, 2007
I was told by a coleague that they are not. Is that true ?
Somehow what he is saying makes sense because the lab exam will test that anyway.
The command line itself is always a subject...
you have to know the commands otherwise you will not pass.
If thats's not an answer to your question please rephrase your question.
#If you find this post usefull
#please don't forget to rate this
#Iwan Hoogendoorn
#CCIE#13084
rafa_lanna Fri, 02/23/2007 - 05:01
Hi friend,
In fact, you don't have to issue any command in a text box during the exam.
But could be there some questions that presents the IOS commands and you should know what are the correct results of it.
Rate this post if I helped you.
Best regards,
Rafael Lanna
