ADSL2/2+ Support
Feb 22nd, 2007
Trying to work out which platforms support ADSL2/2+. From what I can tell, the ADSL HWICs for the ISRs do, and the 857/876/877s do also. However the WICs don't, hence neither do 1700s or 2600s.
Is that correct?
Thanks in advance.
Overall Rating: 5 (1 ratings)
ahmednaas Fri, 02/23/2007 - 01:37
Correct. You need the HWIC-1ADSL to get 2/2+ support which are supported on the platforms you mention.
