NM-16ESW and a HWIC-9ESW in the same 2811 why doesn't it work?
I have a 2811 router and no space for equipment. I put a NM-16ESW switch module in it and it worked great. Later I needed POE for a number of devices, so I installed an HWIC-D-9ESW-POE card with a new power supply. Now I can connect on any device on the HWIC but not the NM-16ESW.
It's all the same VLAN, but I can't even ping the VLAN interface from a device connect to the NM-16ESW. Plug it into the HWIC and the device can ping up a storm.
Any ideas?
glen.grant Thu, 02/22/2007 - 17:24
Did you connect the 2 switches together with a external cat 5 cable , you must tie them together if you want them as a single switch.
Configuring Intrachassis Stacking
Perform this task to extend Layer 2 switching in the router by connecting the Gigabit Ethernet ports of the EtherSwitch network module.
SUMMARY STEPS
1. enable
2. configure terminal
3. interface gigabitethernet slot/port
4. switchport stacking-partner interface gigabit slot/port
5. exit
DETAILED STEPS
Command or Action
Purpose
Step 1
enable
Example:
Router> enable
Enables privileged EXEC mode.
?Enter your password if prompted.
Step 2
configure terminal
Example:
Router# configure terminal
Enters global configuration mode.
Step 3
Example:
Router(config)# interface gigabitethernet 2/0
Selects the Gigabit Ethernet interface to configure.
Step 4
switchport stacking-partner interface gigabitethernet slot/port
Example:
Router(config-if)# switchport stacking-link interface gigabitethernet 3/0
Creates the intrachassis stacking between the current Gigabit Ethernet (GE) interface and the stacking link partner GE interface.
?In this example, GE interface 2/0 is stacked on GE interface 3/0 to form an extended VLAN within one chassis on the router.
Step 5
exit
Example:
Router(config-if)# exit
Exits interface configuration mode and returns the router to global configuration mode.
?Repeat this command to exit global configuration mode and return to privileged EXEC mode.
sachinraja Thu, 02/22/2007 - 17:28
Agree with Glen.. this is the best way of doing this ....
Thanks for the info glen..
Raj
sachinraja Thu, 02/22/2007 - 17:25
Hello murphy,
are u not able to ping between the end stations connected on these cards ?? is the local communication within the modules working ?? You basically need to give a layer 3 vlan IP address for you to enable access between the cards.. this is a router module and hence the router has to know how to forward the packets to the end stations..
do let us know in detail..
Raj
mihanlin Mon, 02/26/2007 - 19:16
Unfortunately you need a gig uplink port on each of the cards for it to work.
The following FAQ describes it in detail:
http://www.cisco.com/en/US/products/hw/modules/ps2643/products_qanda_item09186a00802c9e7a.shtml#qa12
"An intrachassis stack requires a Gigabit Ethernet interface on each module. You must connect the modules externally with the Gigabit Ethernet interfaces and a crossover cable."
The 16-port EtherSwitch NM can accept a single-port Gigabit Ethernet daughtercard.
Hope this helps.
Michael
Cisco TAC - LAN Switching
