Connecting to a switch with Windows Vista and no serial port
Feb 22nd, 2007
Is this possible with a Cisco 2900 or 6500 series?? What do I need to acheive this? I have an HP laptop running vista and only USB ports. Thanks!
Overall Rating: 3.5 (3 ratings)
purohit_810 Thu, 02/22/2007 - 18:05
To connect switch console port, you must have to required COM port on your PC.
IF your laptop has no COM port, please purchase USB to COMPORT conver... connect with it console cable and access to switch.
Enjoy.
Dharmesh Purohit
washishimi Thu, 02/22/2007 - 18:08
Thanks! What about Hyper Terminal. It is not part of Vista. Any suggestions for a free solution?
ahmednaas Thu, 02/22/2007 - 23:06
Caveat Emptor. The USBtoSerial might not work on Vista due to lack of drivers. Test before you buy.
You can download a free copy of Hyperterminal from http://www.hilgraeve.com. Will it work on Vista? If you try it, let us know.
Finally, I remember seeing a bluetooth gizmo on the web that would let you use bluetooth to access the console on Cisco devices.
purohit_810 Fri, 02/23/2007 - 13:18
Hyperterminal comes with windows free of charge.
If your Operating system has no Hyper terminal... Please you can update from windowd vista CD by going into Add/remove componenets --->
Dharmesh Purohit
washishimi Wed, 02/28/2007 - 09:52
Just to update everyone:
Using my new HP Pavillion dv6000 laptop with Windows Vista Home Premium, a keyspan USA-19HS USB High Speed Serial Adaptor (with the vista beta drivers available on their website), and a free download of hyper terminal private edition from the hilgraeve.com site, I was able to log into cisco switches and configure with no issues just as if I was on my old Dell laptop.
Thanks everyone!
