AAA and TACACS on everything BUT NOT console
Feb 22nd, 2007
Would like to enable login authentication AND enable authentication on VTY but NOT console. Console should authenticate locally for both user and privilige modes ... I can't seem to seperate the 'enable' piece ... any thoughts?
daviddtran Thu, 02/22/2007 - 19:17
I do not think you can separate method list for
the enable piece. I've asked Cisco about this
in the past and they told me that it is not
possible. You can have a different method list
for the console for the "exec" mode but not
the enable or privilege mode. It is either
"tacacs" or "enable" or some other
combinations but not a separate method list for "enable" by itself. Maybe cisco added
this new feature in 12.4. I've my my testing
on both 12.2T and 12.3T and, IMHO, it is not
possible to separate the enable piece. Here
is my config:
username cisco password cisco
enable secret cisco
aaa authentication login notac local
aaa authentication login VTY group tacacs+ local
aaa authentication login web local enable
aaa authentication enable default group tacacs+ enable
aaa authorization console
aaa authorization config-commands
aaa authorization exec notac none
aaa authorization exec VTY group tacacs+ if-authenticated none
aaa authorization commands 0 VTY group tacacs+ if-authenticated none
aaa authorization commands 1 VTY group tacacs+ if-authenticated none
aaa authorization commands 15 VTY group tacacs+ if-authenticated none
aaa authorization network VTY group tacacs+ if-authenticated none
aaa accounting exec TAC start-stop group tacacs+
aaa accounting exec VTY start-stop group tacacs+
aaa accounting commands 0 TAC start-stop group tacacs+
aaa accounting commands 0 VTY start-stop group tacacs+
aaa accounting commands 1 TAC start-stop group tacacs+
aaa accounting commands 1 VTY start-stop group tacacs+
aaa accounting commands 10 TAC start-stop group tacacs+
aaa accounting commands 15 TAC start-stop group tacacs+
aaa accounting commands 15 VTY start-stop group tacacs+
aaa accounting network VTY start-stop group tacacs+
aaa accounting connection TAC start-stop group tacacs+
aaa session-id common
line con 0
exec-timeout 0 0
accounting exec VTY
logging synchronous
login authentication notac
line vty 0 15
exec-timeout 0 0
accounting exec VTY
login authentication VTY
