Trunk Speed/Duplex settings
Feb 22nd, 2007
Trunk doesnt establishes when the ports are set to Manual 100 Mbps and Full Duplex.
combinations
Sw 1 -> Sp - 100, Du - Full
Sw 2 -> Sp - 100, Du - Full
Result - trunk fails
Sw 1 -> Sp - A, Du - A
Sw 2 -> Sp - 100, Du - A
Result - trunk establishes in Half duplex, 100 MBPS
why the trunks do not establish when both sides are set for manual speed and duplex? it is recommended this way but trunk doesnt establish.
purohit_810 Thu, 02/22/2007 - 18:02
First How can you say trunk don't establish?
Please tell me error or behaviour ... that switch shows?
Dharmesh Purohit
jaravinthan Mon, 02/26/2007 - 12:49
The switch ports are now set to Auto for speend and duplex. In this case the trunk establishes between switches if the switch port mode is set to trunk. If at one end the spped or duplex is set manually the trunk disconnects and the port status says "disconnected"
glen.grant Thu, 02/22/2007 - 19:07
My guess is that you have auto mdix on and you are using a straight thru cable . Auto mdix will only work when the ports are set as auto . Turn auto mdix off on the ports , use a crossover cable and you should be able to hardcode the ports if you want though you really don't need to between pieces of cisco gear as their autonegotiate function works well. If you set both ports in your current setup to auto for speed and duplex the trunk should work normally also .
jaravinthan Mon, 02/26/2007 - 12:53
i am not sure of the cable as these devices are remotely managed. Auto mdix is not on. The port configuration is as follows
== port on one end==
switchport mode trunk
macro description cisco-switch
auto qos voip trust
spanning-tree portfast trunk
spanning-tree link-type point-to-point
==settings on other end==
auto qos voip trust
glen.grant Mon, 02/26/2007 - 17:41
Are you sure auto mdix is not on ? Normally it will say it on the port interface if it is not on . there is no other reason 2 hardcoded ports would not come up as trunks...
