ACL Help!
Feb 23rd, 2007
Dear All!
I have Cisco 2821 installed in my company. In this box
interface Serial0
ip address xxx.xxx.125.142 255.255.255.252
and the ISP has aloted 8 Ip pool for our server usages. that is xxx.xxx.125.144 255.255.255.248.
I want to impelement ACL on Serial 0 at with
ip access-group 115 in. And I want only required IP pool traffic out from serial interface and in last line don't want to right line ip permit any any. I want to implicite deny all other traffic. with this line access-list 115 deny ip any any.
I hope you will be understand what I actually want to implement in this ACL.
waiting your favaourable reply.
I don't understand your question ...
You want an outbound ACL for xxx.xxx.125.144 255.255.255.248 ?
So:
- what are the IP's that are allowed to talk to the inside?
- What are the IP's that are allowed to talk to the outside?
The ACL need to be implemented on S0
The ACL name has to be 115
#If you find this post usefull
#please don't forget to rate this
#Iwan Hoogendoorn
#CCIE#13084
royalblues Fri, 02/23/2007 - 00:53
friend,
You can use the following access-list
access-list 115 permit ip x.x.125.144 0.0.0.7 any
interface serial 0
ip access-group 115 out
This will allow traffic only from the subnet mentioned out of the interface. all other traffic will be implicitly denied.
HTH, rate if it does
Narayan
Anonymous (not verified) Fri, 02/23/2007 - 01:44
Dear Iwan!
As I have told we have public IP Pool:
I want these server which are using above IP Pool IP Out from Serial and can get any service e,g able to use internet and make vpn to head office. like this ACL line which will clear u all:
access-list 115 permit ip xxx.xxx.125.144 0.0.0.7 any
This host will be able to ping out side any machine.
access-list 115 permit icmp host xxx.xxx.125.148 any echo
access-list 115 permit icmp host xxx.xxx.125.148 any echo-reply
Only One Machine/Host on Branch office can ping my serial 0 IP address:
access-list 115 permit icmp host xxx.xxx.12.80 host xxx.xxx.125.142 echo
access-list 115 permit icmp host 2xxx.xxx.12.80 host xxx.xxx.125.142 echo-reply
access-list 115 deny ip 127.0.0.0 0.255.255.255 any
access-list 115 deny tcp any any eq 135
access-list 115 deny udp any any eq 135
access-list 115 deny tcp any any eq 137
access-list 115 deny tcp any any eq 138
access-list 115 deny tcp any any eq 139
access-list 115 deny tcp any any eq 445
access-list 115 deny tcp any any eq 593
access-list 115 deny udp any any eq 1434
access-list 115 deny tcp any any eq 4444
access-list 115 deny udp any any eq netbios-ns
access-list 115 deny udp any any eq netbios-dgm
access-list 115 deny udp any any eq netbios-ss
access-list 115 deny tcp any any eq telnet
access-list 115 deny udp any any eq tftp
access-list 115 deny icmp any any
interface Serial0
if u want to any addtional information. U can ask.
