Modify the default Auto Attendant script
Feb 23rd, 2007
Operator extension is 9
So, I would like to modify the AA script
?Answers a call
?Plays a user-configurable welcome prompt
?Plays a main menu prompt that asks the caller to perform one of two actions:
?Press 1 to enter an extension number.
?Press 9 for the operator.
Anyone can help me
Mohamed
lpezj Fri, 02/23/2007 - 03:33
If you have CRS script Editor you can do that, modifying the aa.aef. After that, change the old aa.aef file, replace it for the one that you have changed and restart the CRS engine.
Hope this helps,
Juan Luis
moabdallah Fri, 02/23/2007 - 05:59
I don't have experince in editor
Which steps need to be modified in the script ?
Mohamed
