Edge switch probs
Feb 23rd, 2007
Hi all,
This is regading edge Switch(Model 3560 PoE ),Right now we have project which is running around 300 access point in the N/W,Day by day we are adding the new access point to N/W,But from 2 days b4 we have started facing probs adding access point to N/W,Pls find the attachmnet of switch tech-support file,whih shows the access point is connectd to Edge switch as well as VLAN Database,We have got 2 VLAN for managing the access point VLAN ID is 254&253,The access point which is belongs to 253 is able to discover the same in WISM(Wireless controller),But the access point which is belong to 254 vlan is not able to communicate with WISM,We tried to reset the access point ,even after we are not able to get the same in WISM also we have tried the same connecting to CORE directly,and we are able to get the discover the same in WISM.We have DHCP running in core for the access point to communicate with WISM on the first time.After that we are assiging the IP staticaly..And other application which is running in the Edge switch are working fine(IP-Tel,IPTV),we have rewrie the config the swtech alos,even that its nt gettg communcate.
Any suggestion will be g8 for me..
Regds
Saji K.S
