failed to backup configuration to pc on catalyst 500
Feb 23rd, 2007
Can anybody please tell me how I can backup the C500 configuration to PC.
you can use either just copy/paste in the terminal ... SNMP or use TFTP.
when you use a Terminal program that has the feature to log your output/input om the CLI you can do a "sh run" of "write terminal" on CatOS and it will backup :-)
With TFTP its the most handiest ... or you can use an external third party application called "Kiwi CatTools" (google for that)
If you find this post usefull
please don't forget to rate this
Iwan Hoogendoorn
