ICM Reports Format
Feb 23rd, 2007
I have never worked on an ICM but hoping to have hands on asap. Till then i am trying to gain as much theritical knowledge as possible.
I have searched a lot of docs but unable to find the file type ( format) of the reports captured by ICM.
Thanks in advance !
Overall Rating: 5 (1 ratings)
lpezj Fri, 02/23/2007 - 04:14
ICM uses Webview to generate reports from the data stored in a SQL Server Database in a Distributor (historical data and realtime data).
Webview reports are made using Sybase Infomaker. This tool generates files '.pdb' files on the Webview component (normally in a Distributor node).
You can add new reports on Webview using Powerbuilder.
Hope this helps,
Juan Luis
abhishek2525 Fri, 02/23/2007 - 04:40
Hi Juan
Thanks for the prompt reply.
Can i get my hands on some simulator software where i can look at the functionalities of ICM?
Also if possible some simulator for CCM?
lpezj Fri, 02/23/2007 - 04:50
There is no simulator. If you would have got the ICM software you can install all the components in one machine, but only for a lab system.
Juan Luis
abhishek2525 Fri, 02/23/2007 - 04:53
oh ok.
I am looking at it from a lab perspective only. I cannot afford to buy it from Cisco. Any web site that would give me an older version of the software for a cheaper price?
