Min Required Flash Memory & DRAM
Feb 23rd, 2007
I have Cisco 2821. With IOS version:c2800nm-ipbase-mz.123-8.T8.bin
Cisco 2821 (revision 53.51) with 253952K/8192K bytes of memory.
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
can anybody tell me can i upgrade latest IOS 12.4 on my router? or I need additional flash memory & DRAM hardware before for this ios upgrade.??
Please advise.
Anonymous (not verified) Sun, 02/25/2007 - 21:59
Thx Hoogen! But i think this link for download IOS. I have no access to download software :( Thxxxxx for your help....!
purohit_810 Fri, 02/23/2007 - 09:04
You can get an information from about IOS Feature, Memory requirement as well as You can compare your old IOS and NEw IOS on
www.cisco.com/go/fn
Dharmesh Purohit
bvsnarayana03 Sun, 02/25/2007 - 23:18
Why dont you prefer GD IOS, unless you requires specific features from ur IOS.
