VPN client does not get login prompt
Feb 23rd, 2007
I am trying to get a VPN client to get a login prompt and login into an ipsec vpn. It cannot do this although it can ping the remote end which has an ip address of 65.114.54.98. I have attached the log from the VPN client which is as follows:
Cisco Systems VPN Client Version 4.9.00 (0050)
Copyright (C) 1998-2005 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Mac OS X
Running on: Darwin 8.8.1 Darwin Kernel Version 8.8.1: Mon Sep 25 19:42:00 PDT 2006; root:xnu-792.13.8.obj~1/RELEASE_I386 i386
55 13:29:24.989 02/22/2007 Sev=Info/4 CM/0x43100002
Begin connection process
56 13:29:24.989 02/22/2007 Sev=Warning/2 CVPND/0x83400011
Error -28 sending packet. Dst Addr: 0x0A2581FF, Src Addr: 0x0A258102 (DRVIFACE:1158).
57 13:29:24.990 02/22/2007 Sev=Info/4 CM/0x43100004
Establish secure connection using Ethernet
58 13:29:24.990 02/22/2007 Sev=Info/4 CM/0x43100024
Attempt connection with server "65.114.54.98"
59 13:29:24.990 02/22/2007 Sev=Info/4 CVPND/0x43400019
Privilege Separation: binding to port: (500).
60 13:29:24.990 02/22/2007 Sev=Info/4 CVPND/0x43400019
Privilege Separation: binding to port: (4500).
61 13:29:24.991 02/22/2007 Sev=Info/6 IKE/0x4300003B
Attempting to establish a connection with 65.114.54.98.
62 13:29:25.103 02/22/2007 Sev=Info/4 IKE/0x43000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to 65.114.54.98
63 13:29:25.104 02/22/2007 Sev=Info/4 IPSEC/0x43700008
IPSec driver successfully started
64 13:29:25.104 02/22/2007 Sev=Info/4 IPSEC/0x43700014
Deleted all keys
65 13:29:30.586 02/22/2007 Sev=Info/4 IKE/0x43000021
Retransmitting last packet!
66 13:29:30.586 02/22/2007 Sev=Info/4 IKE/0x43000013
SENDING >>> ISAKMP OAK AG (Retransmission) to 65.114.54.98
67 13:29:36.084 02/22/2007 Sev=Info/4 IKE/0x43000021
68 13:29:36.084 02/22/2007 Sev=Info/4 IKE/0x43000013
69 13:29:41.584 02/22/2007 Sev=Info/4 IKE/0x43000021
70 13:29:41.584 02/22/2007 Sev=Info/4 IKE/0x43000013
71 13:29:46.584 02/22/2007 Sev=Info/4 IKE/0x43000017
Marking IKE SA for deletion (I_Cookie=CD71334CC08B4802 R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
72 13:29:47.585 02/22/2007 Sev=Info/4 IKE/0x4300004B
Discarding IKE SA negotiation (I_Cookie=CD71334CC08B4802 R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
73 13:29:47.585 02/22/2007 Sev=Info/4 CM/0x43100014
Unable to establish Phase 1 SA with server "65.114.54.98" because of "DEL_REASON_PEER_NOT_RESPONDING"
74 13:29:47.585 02/22/2007 Sev=Info/5 CM/0x43100025
Initializing CVPNDrv
75 13:29:47.586 02/22/2007 Sev=Info/4 CVPND/0x4340001F
Privilege Separation: restoring MTU on primary interface.
76 13:29:47.586 02/22/2007 Sev=Info/4 IKE/0x43000001
IKE received signal to terminate VPN connection
77 13:29:48.584 02/22/2007 Sev=Info/4 IPSEC/0x43700014
Deleted all keys
78 13:29:48.584 02/22/2007 Sev=Info/4 IPSEC/0x43700014
Deleted all keys
79 13:29:48.584 02/22/2007 Sev=Info/4 IPSEC/0x43700014
Deleted all keys
80 13:29:48.584 02/22/2007 Sev=Info/4 IPSEC/0x4370000A
IPSec driver successfully stopped
