weird error when doing "write mem"
Feb 23rd, 2007
Whenever I performed "write mem", I am
getting this error:
NYC#wr
Building configuration...
% Configuration buffer full, can't add command: line vty 0
%Aborting Save. Compress the config.[OK]
NYC#
NYC#wr
NYC#
Basically, I can not save my config into
the flash. How can I fix this? Thanks.
David
NYC#sh ver
IOS (tm) C2600 Software (C2600-IK9O3S3-M), Version 12.3(12), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 29-Nov-04 15:40 by kellythw
Image text-base: 0x80008098, data-base: 0x819F9E70
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-IK9O3S3-M), Version 12.3(12), RELEASE SOFTWARE (fc3)
NYC uptime is 2 days, 8 hours, 38 minutes
System restarted at 03:21:09 UTC Wed Feb 21 2007
System image file is "flash:c2600-ik9o3s3-mz.123-12.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco 2621 (MPC860) processor (revision 0x102) with 59392K/6144K bytes of memory.
Processor board ID xxxxxxx (xxxxxxx)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
3 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
NYC#
1 vote
Overall Rating: 5 (1 ratings)
rodsal.rivas Tue, 08/13/2013 - 08:13
i got the same error..
Richardson-CE1(config)#wr        do wr
% Warning: Saving this config to nvram may corrupt any network management or security files stored at the end of nvram.
Continue? [no]:
% Configuration buffer full, can't add command:  description ALLOW-GRE-IPSEC-PREFIXES-FROM-MIXME-ROUTER
%Aborting Save. Compress the config, Save it to flash or Free up space on device[OK]
i did service compress-config but the router is very slow right now.. any thoughts what might be causing the slow response of the device?
