ssh in routers and switches
Feb 23rd, 2007
wich ios must I have in order to establish ssh on routers and switches?
thanks!
rajivrajan1 Fri, 02/23/2007 - 05:21
SSH Version 1.0 (SSH v1) server was introduced in some IOS platforms and images starting in Cisco IOS Software Release 12.0.5.S.
SSH client was introduced in some IOS platforms and images starting in Cisco IOS Software Release 12.1.3.T.
SSH terminal-line access (also known as reverse-Telnet) was introduced in some IOS platforms and images starting in Cisco IOS Software Release 12.2.2.T.
SSH Version 2.0 (SSH v2) support was introduced in some IOS platforms and images starting in Cisco IOS Software Release 12.1(19)E.
http://www.cisco.com/warp/public/707/ssh.shtml
hoogen_82 Fri, 02/23/2007 - 07:03
When you are looking at the images look for a k9 this is keyword for any ios supporting ssh on router or switch.
Hoogen
Do rate if this soln helps :)
Richard Burts Fri, 02/23/2007 - 07:05
In addition to the consideration of which versions introduced support for which implementations of SSH, be aware that there is also a feature set dependency. SSH depends on encryption and the code that you run must support cryptography. Some feature sets do support this (Advanced Security, Advanced Enterprise Services, IP IPSec 3DES) and some do not (IP BASE).
Rick
bvsnarayana03 Fri, 02/23/2007 - 08:18
for SSH, IOS must support crypto. Look for k series in IOS file.
Use SSH v2 as far as possible.
